TwinTurbo.NET: Nissan 300ZX forum - Re: Not much comes up for my problem
Subject Re: Not much comes up for my problem
Posted by 550HPTT on August 12, 2008 at 9:59 AM
  This message has been viewed 82 times.
In Reply To Not much comes up for my problem posted by RedTTZ91(OK) on August 12, 2008 at 09:43 AM
Message You said the A/C compressor and relay work fine. Your problem is simply between point A and B. You should look closely at the plug. Get one of those inline splicers/piggyback connectors and clamp it in various spots of the wire between point A and B with a hot attached to it to narrow down your bad spot. I would start close the compressor to eliminate your most likely cause.. the plug
I do not fear what the future holds for me, I am not afraid to die.
