TwinTurbo.NET: Nissan 300ZX forum - Not much comes up for my problem
RedTTZ91(OK)
on August 12, 2008 at 9:43 AM
In your own words :)
posted by 550HPTT
on August 12, 2008 at 07:49 AM
And I traces what I could via the factory service manual and nothing is fixed yet so obviously Im gonna post on here for what I cant find, Not trying to be an asshole or anything.
ac comp question,
RedTTZ91(OK)
22:27:02 08/11/08
does your AC blow cold?
aliaZ
22:32:07 08/11/08
Yes I recharged it and it blows cold when I hard wire
RedTTZ91(OK)
22:37:27 08/11/08
run a diagnostic on it
aliaZ
23:04:03 08/11/08
Re: ac comp question,
tyler@boostpro.net
22:43:42 08/11/08
already tried two different relaysm It works on every fire
RedTTZ91(OK)
22:49:16 08/11/08
Relays* Wire* Sorry its dark outside (n/m)
RedTTZ91(OK)
22:53:45 08/11/08
The A/C relay is between the fuse and the compressor though.
Karl (MD)
23:02:46 08/11/08
I know the relay is fine I touched it to the wiring on the
RedTTZ91(OK)
23:10:41 08/11/08
Ah, sorry, I misread your previous post.
Karl (MD)
23:26:04 08/11/08
Yeh, but the wire for the clutch goes into the harness and I
RedTTZ91(OK)
23:32:37 08/11/08
Did you try from both sides of the relay to make sure you
550HPTT
10:02:44 08/12/08
Perhaps there's an issue with your A/C relay? (n/m)
Karl (MD)
22:44:44 08/11/08
Correction it turns off when the car turns off, but the
RedTTZ91(OK)
23:13:12 08/11/08
Hm, so where exactly do you have the compressor connected? (n/m)
Karl (MD)
23:52:50 08/11/08
I just ran it straight to the fuse box under the hood
RedTTZ91(OK)
00:22:58 08/12/08
550HPTT
07:49:41 08/12/08
Not much comes up for my problem -
RedTTZ91(OK)
09:43:20 08/12/08
Re: Not much comes up for my problem
550HPTT
09:59:47 08/12/08
its not the plug, I spliced in after the plug and
RedTTZ91(OK)
11:39:39 08/12/08
have you run a diagnostic yet? (n/m)
aliaZ
12:13:29 08/12/08
Ok to make sure we are on the same page here....
550HPTT
12:18:41 08/12/08
No I spliced it from the
RedTTZ91(OK)
14:01:17 08/12/08
