TwinTurbo.NET: Nissan 300ZX forum - No, it does adjust camber, however the toe will also
Fast300
on August 11, 2008 at 9:05 PM
The guy said that bolt was for TOE. When he showed me, it (
posted by jamil
on August 11, 2008 at 04:26 PM
change a bit and should be checked after the camber adjustment.
The toe is adjusted at each of the Super HICAS lower links.
Rear Camber Adjustment not possible according to dealer
jamil
13:04:55 08/11/08
The top rear bolt holding the a-arm on is the camber adjust
550HPTT
14:22:18 08/11/08
It's also possible that the cam bolt does not offer enough
zellamay
15:13:21 08/11/08
jamil
16:26:43 08/11/08
I would go else where. It should be second nature for him
550HPTT
18:28:08 08/11/08
No, it does adjust camber, however the toe will also -
Fast300
21:05:49 08/11/08
Consensus: Go to another shop. I hope you didn't pay this
zellamay
10:01:20 08/12/08
I believe this guy when he said he called two dealerships
jamil
10:08:07 08/14/08
