TwinTurbo.NET: Nissan 300ZX forum - You can't adjust the camber with stock front suspension
Subject You can't adjust the camber with stock front suspension
Posted by 550HPTT on August 11, 2008 at 6:39 PM
In Reply To to be honest, the wheel looks perfecly perpendicular to the posted by Heavyarms2050 on August 11, 2008 at 06:29 PM
Message here's how you can do a half-ass alignment check...
Find the very center of the front of the driver's tire, have someone hold the tape measure there, pull it to the very center of the passenger tire and get your measurement
Now do the same for the backside of the front tires. measure from center to center of them.
If the alignment is off then the measurement from the front of the tires should differ from the measurements from the backside of the tires. (in your case the front side measurement should be less than the rear side measurement)
If both measurements or the same then your good.
I do not fear what the future holds for me, I am not afraid to die.
