TwinTurbo.NET: Nissan 300ZX forum - Run a nylon line thru the grommeted hole for the hood cable.
Subject Run a nylon line thru the grommeted hole for the hood cable.
Posted by Gordo 93TT Daytona on August 11, 2008 at 1:52 PM
  This message has been viewed 110 times.
In Reply To i jammed a screwdriver through there, it is pretty deep >> posted by WE350Z on August 11, 2008 at 01:20 AM
Run an .125" nylon vacum line, not a rubber line. The nylon line can be pulled thru right next to the cable without any concerns of being crushed or squeezed.
FYI there is also a similar access port on the passengers side where the AC condensor overflow tube runs thru the firewall. It is identified as a formed rubber hose about .750" diameter. Go under the car on a not humid day with the AC on and you can easily spot it. It is easy access from the interior, once the carpet is pulled up. It is under the ECU.
Gordo
_________________________________________________
