TwinTurbo.NET: Nissan 300ZX forum - Rebuild question- Please Help, at a deadend
Subject Rebuild question- Please Help, at a deadend
Posted by lugerz on August 10, 2008 at 11:56 AM
  This message has been viewed 109 times.
Message Here's my last 4 years in a nut shell
rebuilt engine
blew turbos
replaced turbos with z1 515s
engine knocked
so replaced crankshaft main bearings, rod bearings and oil pump
still smoked
so replaced valve seals
I have driven it 20 minutes and it still smokes at idle and driving...
How long do I need to drive before old oil is burnt up?
In last week I have done compression test, results within spec and yesterday did a leak down test with all clylinders getting a green light.
I used an offbrand leak-down tester and it was hard to zero out before doing each cylinder. Would this skew my results?
I also looked in the intercoolers no oil....
I am planning on driving on interstate for about 30 minutes to see if that clears it up any. Or taking the exhaust off to see if it is just residual oil in the exhaust making it smoke.
Any other sugggestions?
