TwinTurbo.NET: Nissan 300ZX forum - the grommet is just above the plastic housing that...
Subject the grommet is just above the plastic housing that...
Posted by David G on August 10, 2008 at 1:54 AM
  This message has been viewed 127 times.
In Reply To driver side firewall for running vacline for boost guage > posted by WE350Z on August 10, 2008 at 01:06 AM
Message contains the fuse box. The grommet is about 1" in diameter. Stick a long thin phillips screw driver into the grommet to enlarge an area. Then shove about 2 ft of the hose into the engine compartment. You can not see the grommet from the engine compartment so just use long pliers to grasp the hose and pull it up.
David G
