TwinTurbo.NET: Nissan 300ZX forum - 2 Quick Boost Controller/Vac Line Q's
Subject 2 Quick Boost Controller/Vac Line Q's
Posted by WE350Z on August 09, 2008 at 8:30 PM
  This message has been viewed 652 times.
Message 1) Autozone did not have any 6MM ID vacline tubing. Only 6.4MM and 5.6MM. Is the 5.6MM OK to use? Seems to fit on the t's just fine, just a little bit snugger. If no where can I get some 6MM? I only have the 10ft of blue tube that came with my Blitz SBC-iD III.
2) I am going with the option described in step 7b of the Blitz SBC-iD III FAQ. I know it's simple but I wanted to clarify and make absolutely sure I have the steps right since the writeup is a little vague:
- Disconnect driver and passenger side stock boost solenoid electrical connectors.
- T the two vac lines together that come off the passenger and driver side boost port nipples on the uppermost/innermost hard plastic intake pipes (pic below) and connect them to the "OUT" port of the SBC solenoid.
- T off the vac line routed from the "IN" port of the SBC solenoid using equal lengths to connect to the passenger and adriver side boost port nipples on the uppermost/innermost hard plastic intake pipes (pic below).
Is this correct or do I have it reversed? Just curious with this configuration do we still pass through the now inactive stock boost solenoids?
Thanks guys!
_____________________
2006 Scion tC (Sold)
2004 Yamaha YZF-R6
2003 Nissan 350Z Track (Sold)
2000 BMW X5 4.4i
1993 300ZX Twin Turbo
1985 Nissan 300ZX NA (Sold)
WE350Z at gmail dot com
http://WE350Z.com
