TwinTurbo.NET: Nissan 300ZX forum - I wasn't aware of water being in the engine.
itsghoZt
on August 09, 2008 at 12:53 PM
That would'nt of seized up your engine...
posted by itsghoZt
on August 09, 2008 at 12:15 PM
if you have water in your cylinders, then you need to search and take advice and you might get lucky and get the car to turn over and run, unless the car was running when water entered the chambers
I think my engine seized up! VERY DEPRESSING
BiggMerv
08:13:59 08/09/08
have you removed your spark plugs?
aliaZ
08:23:41 08/09/08
Re: have you removed your spark plugs?
BiggMerv
08:40:00 08/09/08
sure
aliaZ
09:07:08 08/09/08
When I blow the head, it was still driveable.
BiggMerv
12:03:36 08/09/08
itsghoZt
12:15:23 08/09/08
Depending on the amount of water in the cylinder it could
550HPTT
12:26:11 08/09/08
That idea sounds good, but what if I
BiggMerv
16:56:46 08/09/08
There are dots on the crank and cam gears, you line them
550HPTT
17:06:58 08/09/08
you have to remove the water first (n/m)
aliaZ
17:05:24 08/09/08
Thats why I stated "depending" on the amount. I should
550HPTT
17:11:33 08/09/08
I wasn't aware of water being in the engine. -
itsghoZt
12:53:21 08/09/08
