TwinTurbo.NET: Nissan 300ZX forum - Sounds like your battery cable is bad or have a bad
Subject Sounds like your battery cable is bad or have a bad
Posted by 550HPTT on August 09, 2008 at 8:47 AM
  This message has been viewed 116 times.
In Reply To alternator test results posted by alpin3 on August 08, 2008 at 05:23 PM
Message connection on either end. If the battery does not get a full charge after use it will fail. You should ohm your cable from one end to the other, i believe anything more than one ohm is bad. At the least you should see 13.7 at the battery with the car running.
I do not fear what the future holds for me, I am not afraid to die.
