TwinTurbo.NET: Nissan 300ZX forum - How to remove window buttons (slider replacement)
Subject How to remove window buttons (slider replacement)
Posted by J_Wright on August 08, 2008 at 11:36 PM
  This message has been viewed 361 times.
Message I found an easy way to remove the outside window buttons when doing the slider replacement last week. All you need is two clamps, a small block of wood, and a rubber grommet (from a garden hose in my case). Put the grommet on the wood block and position so that the grommet is on and around the window button. Then put a clamp on each end of the wood, soak the button in a little PB Blaster, and remove the button with an appropriate tool (I used needle nose pliers inserted in the two button holes). Easy and only took a few minutes for the PB Blaster.
Thought this might help for the below posts
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=910877 ]
[ http://www.twinturbo.net/net/viewmsg.aspx?forum=technical&msg_id=1001642&forum=technical&dtSearch=0 ]
Moderator, move at will
  • How to remove window buttons (slider replacement) - J_Wright 23:36:26 08/08/08
