TwinTurbo.NET: Nissan 300ZX forum - More likely you've developed a vacuum leak someplace
doug8867
on August 06, 2008 at 2:22 PM
Idle rock steady at 1200 rpms after engine warmed up?
posted by Fly-Surf
on August 05, 2008 at 07:09 AM
than the regulator stuck open so I would closely examine all air hoses and/or
perform a boost leak test to check for leaks.
Fly-Surf
07:09:53 08/05/08
Could be Air Regulator stuck open/dead or maybe
Audioquest
08:38:18 08/05/08
Location of Air Regulator?
Fly-Surf
11:42:53 08/05/08
Petty much dead-center rear of plenum (n/m)
Audioquest
13:26:18 08/05/08
little to the right of dead center actually. The EGR is
doug8867
14:21:24 08/06/08
Not to be trivial, but the EGR is not on the plenum (n/m)
Audioquest
16:10:04 08/06/08
More likely you've developed a vacuum leak someplace -
doug8867
14:22:49 08/06/08
Check TPS
Attila
14:57:30 08/06/08
