TwinTurbo.NET: Nissan 300ZX forum - The slave is not normally a wear part, no matter how you
Subject The slave is not normally a wear part, no matter how you
Posted by doug8867 on August 04, 2008 at 10:04 PM
  This message has been viewed 112 times.
In Reply To Re: Re: Definitely not normal. My original slave lasted 10 years. posted by danvan on August 04, 2008 at 08:13 PM
Message drive it. Basically the piston goes in and out. Doesn't matter if you're
squealing around corners on an autocross track or drag racing. Slaves
usually fail when they rust through due hydroscopic brake fluid and age.
However if the clutch fork is not installed properly or has bent, etc. it could
be applying too much pressure to the slave piston pushing it too far which
is causing it to blow.
There are plenty of long time hard core racers on this site who don't go
through slave cylinders, because hard driving doesn't accelerate their
wear. So you probably won't get much feedback on whether the pathfinder
slave is compatible as the OEM one has always been fine.
You can mask the problem if you want by installing a different type of
slave, but wearing out a slave in 1,500 miles is not normal, so you will
probably end up with the problem again sooner rather than later. Good
luck.
