TwinTurbo.NET: Nissan 300ZX forum - Re: Problem with timing belt removal
Subject Re: Problem with timing belt removal
Posted by txq45 on August 04, 2008 at 9:33 PM
  This message has been viewed 111 times.
In Reply To Problem with timing belt removal posted by BiggMerv on August 04, 2008 at 08:48 PM
Message assuming you're using the pipe on the nut on the underdrive pulley. and you can't turn the engine over? Something's wrong! There's only a couple of things that would give you that much resistance...... car in gear with brake on.. you've set the timing wrong and have a valve hitting the top of a piston...etc.... look for something that can lock up the engine.
