TwinTurbo.NET: Nissan 300ZX forum - Had the same problem on a guys car here locally.
Subject Had the same problem on a guys car here locally.
Posted by Milo (SATX) on August 04, 2008 at 5:59 PM
  This message has been viewed 103 times.
In Reply To extremely mushy brakes posted by jerZey on August 03, 2008 at 02:13 PM
Message It turns out to be the check valve in the hosing leading to the plenum for us. Check valve went back. Easy to check, simply remove and blow on each end one at a time. If you get air both ways it's gone bad. Also, take the time to replace the hoses as well to rule out.
Just my $.02, this assuming you bleed the system correctly of course.
