TwinTurbo.NET: Nissan 300ZX forum - Re: Are the slaves leaking or what? How are they failing?
danvan
on August 04, 2008 at 2:21 PM
Are the slaves leaking or what? How are they failing? (n/m)
posted by doug8867
on August 04, 2008 at 01:46 PM
no not a slow leak it is fairly fast every thing is normal and it starts to get hard to shift then it stops working entierly the seal blows out and all fluid is lost
clutch slave
danvan
10:51:48 08/04/08
doug8867
13:46:58 08/04/08
Re: Are the slaves leaking or what? How are they failing? -
danvan
14:21:41 08/04/08
Sounds like your clutch fork might be damaged (n/m)
na300zx (OH)
14:44:55 08/04/08
Definitely not normal. My original slave lasted 10 years.
doug8867
15:56:38 08/04/08
Re: Definitely not normal. My original slave lasted 10 years. (n/m)
danvan
20:01:47 08/04/08
Re: Re: Definitely not normal. My original slave lasted 10 years.
danvan
20:13:21 08/04/08
The slave is not normally a wear part, no matter how you
doug8867
22:04:41 08/04/08
Re: The slave is not normally a wear part, no matter how you
danvan
22:47:29 08/04/08
He gave you a straight answer
na300zx (OH)
07:15:56 08/05/08
Re: He gave you a straight answer
danvan
00:38:17 08/07/08
4 to 5 inches of freeplay? Did I read that right?
na300zx (OH)
06:12:37 08/07/08
4 to 5 inches is WAY TOO much. Here is info on how to
doug8867
08:06:51 08/07/08
