TwinTurbo.NET: Nissan 300ZX forum - Re: crank pulley removal-engine in car
LADY_Z
on August 03, 2008 at 6:29 PM
posted by LADY_Z
on July 31, 2008 at 09:50 PM
Resting the bar on the sub frame and just touching the ignition worked awesome. Took five seconds :) Thanks again. Now i just need to find TDC on the compression stroke and start doing the timing belt.
LADY_Z
21:50:42 07/31/08
put it in 5th gear (n/m)
aliaZ
21:52:37 07/31/08
Try this...
WoodmanZ
22:06:36 07/31/08
thanks
LADY_Z
22:29:24 07/31/08
You'll also need a good pulley puller to get the pulley
WoodmanZ
12:49:16 08/01/08
2nd - but use caution when doing this and stay safe... (n/m)
jzack
23:55:25 07/31/08
Put a piece of plywood between the pulley and the
zellamay
01:06:55 08/01/08
The e-brake won't stop it. Have someone sit in the car
Audioquest
11:11:37 08/01/08
if it is in 5th gear the e-brake will hold fine
aliaZ
14:59:35 08/01/08
turbo1
15:07:59 08/01/08
5th gear and utilize a breaker bar. Always works for me. (n/m)
Milo (SATX)
15:37:44 08/01/08
Re: crank pulley removal-engine in car -
LADY_Z
18:29:29 08/03/08
