TwinTurbo.NET: Nissan 300ZX forum - basiclly start from the furthest to the Master (n/m)
300znick
on August 03, 2008 at 3:37 PM
Bleed the side farthest from the master cylinder first
posted by ZXRider(SoCal)
on August 03, 2008 at 03:21 PM
extremely mushy brakes
jerZey
14:13:12 08/03/08
gotta keep bleeding... (n/m)
inf
14:23:25 08/03/08
Are you following the proper bleed order? (n/m)
zgene4
14:29:15 08/03/08
Re: Are you following the proper bleed order?
jerZey
14:44:54 08/03/08
ZXRider(SoCal)
15:21:33 08/03/08
basiclly start from the furthest to the Master (n/m) -
300znick
15:37:29 08/03/08
That is the correct order.
Fast300
21:21:05 08/03/08
Are you adding brake fluid as you bleeding them? because
DoodMon(SD)
16:00:53 08/03/08
yes, i made that mistake in the beginning but i realized it
jerZey
16:29:03 08/03/08
were they mushy before you did all this? (n/m)
spyhunterTT(nj)
16:01:27 08/03/08
they were somewhat mushy but that is why i bought all
jerZey
16:31:04 08/03/08
hmmmm could it be your abs pump going out, perhaps?
DoodMon(SD)
17:38:46 08/03/08
Tell us exactly how you are bleeding the brakes. (n/m)
WoodmanZ
08:28:54 08/04/08
Had the same problem on a guys car here locally.
Milo (SATX)
17:59:19 08/04/08
