TwinTurbo.NET: Nissan 300ZX forum - Urgent!!! Clutch Engagement Help
Subject Urgent!!! Clutch Engagement Help
Posted by JSD-ZX on August 02, 2008 at 11:15 PM
  This message has been viewed 107 times.
Message I'm having an a major issue trying to complete my transmission swap.
The problem doesn't seem to be engaging. If i push the pedal completely to the floor I have to struggle to put into 1st gear. Reverse is impossible.
I've made sure to bleed all the air out. I bought a new Clutch Master and Slave cylinder. I also adjusted the pedal switches.
I haven't adjusted the clutch rod yet because im not sure exactly which way i should go. With the issue I'm having do I bring the rod closer to the driver or closer to the firewall? Futhermore, do you think any of this will help or am I having a different issue.
