TwinTurbo.NET: Nissan 300ZX forum - When rebuilding my lifters I had the following notes:
Subject When rebuilding my lifters I had the following notes:
Posted by LitlElvis on August 02, 2008 at 11:45 AM
  This message has been viewed 123 times.
In Reply To is the lifter rebuild easy and straigth forward? what posted by DKaway on August 02, 2008 at 09:05 AM
Message 1) best way to clean the parts is using Berryman Chem-dip; this will remove any oil varnish in a few hours. Just rinse with hot water and blow dry the parts afterwards.
2) there are a lot of little parts that can easily get lost; I used a thin rag to hold all the parts in a wad while I used compressed air to dry them.
3) oil the parts immediately after drying them to prevent any surface rust.
4) re-assembly of the check valve is a pain, after the 24th lifter, you will see what I mean. Make sure all of these are seated properly by listening for the audible "snap" or "click" when they go together.
