TwinTurbo.NET: Nissan 300ZX forum - Help with Z1 SPAL electrical fan kit
Subject Help with Z1 SPAL electrical fan kit
Posted by Z-speed on August 02, 2008 at 9:27 AM
  This message has been viewed 273 times.
Message Those with Z1 SPAL electrical fan kit and Howe radiator ,could you give some idea's on were to mount the thermal switch or any links with pictures of the installation done on a twin turbo Z. I plan to switch from the clutch fan to the SPAL 3000 CFM electric fan to help the engine rev faster ,but i don't have any ideas on how effective the cooling would be since i see most cars that carry the fan are used for racing or off road use. I'm using it for street and long high way runs,does it make sense or just leave the stock fan? Were i live the temperature is always hot,its a tropical climate around 35 degrees maximum. Any feed back would be most helpful, from anyone that uses the Z1 SPAL electrical fan set up since its the same one i am going to install on my Z.Thanks.
  • Help with Z1 SPAL electrical fan kit - Z-speed 09:27:31 08/02/08
