TwinTurbo.NET: Nissan 300ZX forum - Check your tension rod bushings. Check your upper camber
Subject Check your tension rod bushings. Check your upper camber
Posted by MixManMash on August 01, 2008 at 11:45 AM
  This message has been viewed 121 times.
In Reply To Wheel Bearings i think????? HELP posted by Ketch on August 01, 2008 at 10:30 AM
Message arms for play.
If these are warn out, they will cause vibrations at speeds for 50+ mph, depending on how warn out they are.
Make sure your lug nuts are torqued to 78 lb-ft.
Make sure your brake caliper is not loose.
