TwinTurbo.NET: Nissan 300ZX forum - Intermittent issues are really tough but here is what I
Subject Intermittent issues are really tough but here is what I
Posted by kkrofft (OH) on August 01, 2008 at 7:07 AM
  This message has been viewed 219 times.
In Reply To Any ideas on my no start issue? posted by WoodmanZ on August 01, 2008 at 01:08 AM
Message would do.
It has to be fuel or ignition. So do you hear the fuel pump when you turn the key on before you crank it?
If not, it is likely a bad connection in the FP controller.
If yes,then carry a 10mm wrench and a spare spark plug. Next time it quits. pull a coil and put the plug in it. Ground the base of the plug and have someone crank. if no spark then it could be CAS or PTU or one of the harnesses.
You could also pull the ecu codes to be sure it is not a logged error.
KKrofft
