TwinTurbo.NET: Nissan 300ZX forum - When it's idling and the manifold is in a negative
Audioquest
on July 30, 2008 at 6:09 PM
A "weak" pump?
posted by Broke_as_****
on July 30, 2008 at 10:26 AM
state it's supposed to lower the fuel pressure isn't it? Normally at zero it's around 45, and increases per pounds of boost and does the same under vacuum.
Fuel pressure issue: Day 153
Broke_as_****
10:45:18 07/29/08
Damn... I was going to offer you my ECU, but you have
91Z32TT
10:58:22 07/29/08
ar you still prvr equipped (sorry dont want to read all old
gt300zxtt
11:13:36 07/29/08
PRVR is gone (n/m)
Broke_as_****
11:14:49 07/29/08
Damnit I was just going to ask about prvr - since it's
91Z32TT
11:21:31 07/29/08
Re: Fuel pressure issue: Day 153
Chad M (CA)
11:22:04 07/29/08
You'd have to ask JWT about that one
Broke_as_****
11:39:55 07/29/08
Re: You'd have to ask JWT about that one
Chad M (CA)
11:58:49 07/29/08
Re: Re: You'd have to ask JWT about that one
Broke_as_****
14:21:29 07/29/08
Re: Re: Re: You'd have to ask JWT about that one
Chad M (CA)
15:37:20 07/29/08
Re: Re: Re: Re: You'd have to ask JWT about that one
Broke_as_****
16:13:55 07/29/08
Ok I understand now....
Chad M (CA)
16:51:35 07/29/08
It pulls around 15-20 inches at idle
Broke_as_****
17:03:16 07/29/08
Re: It pulls around 15-20 inches at idle
Chad M (CA)
17:15:06 07/29/08
Thanks for chipping in
Broke_as_****
17:37:19 07/29/08
Have you swapped gauges around to rule that out? (n/m)
Audioquest
13:36:55 07/29/08
Yes (n/m)
Broke_as_****
14:05:16 07/29/08
Very odd how in that same piece of fuel line from the tank
Audioquest
16:13:13 07/29/08
That's why I bypassed all of those lines
Broke_as_****
16:17:13 07/29/08
I think your gauge is suspect---->
Audioquest
23:35:03 07/29/08
I've done that
Broke_as_****
00:36:12 07/30/08
Maybe you just got a weak pump? HAve a look at this
Audioquest
08:12:03 07/30/08
A "weak" pump?
Broke_as_****
10:26:41 07/30/08
When it's idling and the manifold is in a negative -
Audioquest
18:09:38 07/30/08
Re: When it's idling and the manifold is in a negative
Broke_as_****
12:27:56 07/31/08
Replace the fuel rails?
LitlElvis
14:57:29 07/29/08
I did a few years ago
Broke_as_****
16:00:15 07/29/08
If it is dropping from the back of the car to the front
Spddracer
18:03:04 07/29/08
Re: If it is dropping from the back of the car to the front
Broke_as_****
18:28:53 07/29/08
