TwinTurbo.NET: Nissan 300ZX forum - 3 questions:
Subject 3 questions:
Posted by DKaway on July 30, 2008 at 8:02 AM
  This message has been viewed 126 times.
Message 1. how do you clean the piston heads without damaging the surface? the pistons are still in the engine block on a stand (engine disassymbled)
2. how can i use the stock DP heat shields with aftermarket Specialty Z DP. they don't screw in place like on the stock ones.
3. when the front facia is removed, then replaced (many people have this same problem i noticed) how or what causes the seperation (or sag) on both side? and how to get it back to normal (fix it)?
Thanks
