TwinTurbo.NET: Nissan 300ZX forum - If it is dropping from the back of the car to the front
Subject If it is dropping from the back of the car to the front
Posted by Spddracer on July 29, 2008 at 6:03 PM
  This message has been viewed 153 times.
In Reply To Fuel pressure issue: Day 153 posted by Broke_as_**** on July 29, 2008 at 10:45 AM
Message it sounds like you may have a volume problem from the pump. Have you checked the tank unit itself to make sure nothing is leaking or a bad hose from the pump to tank unit piping?
2nd, Just because you have voltage at your pump doesnt mean the pump is getting/using all of it. You need to do voltage drop on the ground side.
I would suck monkey balls to get my Z black... (n/m) - scottyfender 02/22/08 23:14:01
