TwinTurbo.NET: Nissan 300ZX forum - Re: Fuel pressure issue: Day 153
Subject Re: Fuel pressure issue: Day 153
Posted by Chad M (CA) on July 29, 2008 at 11:22 AM
  This message has been viewed 171 times.
In Reply To Fuel pressure issue: Day 153 posted by Broke_as_**** on July 29, 2008 at 10:45 AM
Message Sounds like your running a 90-93? ECU program in your car. The
intial prime to the fuel pump with a 95 ECU should be more like
3 seconds. Not sure if that has anything to do with it.
Other than that, have you tested the fuel temp sensor? It only
really controls the PRVR system but who knows. Also have
you tested the fuel check valve? again neither should effect
your pressure, but there both easy tests.
I know how it feels to be at a dead end. I'm on day 900+
of a engine that only overheats at idle, and no closer to
figuring it out than day 1
1995 300ZX TT
