| Message |
I've narrowed down a problem with my brake lights to be the module in the rear quarter that controlls the brake lights switching voltages for high and low. If I move it and play with it, it'll work, then it fails again, so I'm sure there is broken connections/solder inside the module. I've read that people have taken it appart and fixed the solder...posts from 4 or so years ago. Just wondering if anyone has opened it up, and done the fix. There are no screws/clips visible, and I don't want to break the old plastic. This is the module
Thanks
 Stage VI Naturally Aspirated "What kind of lube are you using? Vaseline works well" - Woody75 (Denver) 09:26:01 01/10/08
