TwinTurbo.NET: Nissan 300ZX forum - So I know it is not the radiator fluid because i drained it
Subject So I know it is not the radiator fluid because i drained it
Posted by keffboyer2000 on July 29, 2008 at 11:56 AM
  This message has been viewed 72 times.
In Reply To check your temps with Datascan posted by Ahmed (Chicago) on July 28, 2008 at 09:10 PM
Message and added new stuff to it. The overfill container is also filled to the hot mark so i have plenty of antifreeze in there. I assume the waterpump works because when i was filling the radiator back up i could see the fluid flowing constantly. I checked the fan clutch by spinning it and it did not move real easy but it did move? You should be able to hear that fan kick on while driving or stopped at a stop sign correct? Well could the ecu be a culprit if it already has a bad knocksensor output on it?
