TwinTurbo.NET: Nissan 300ZX forum - Piston rings require a complete teardown. No point
Subject Piston rings require a complete teardown. No point
Posted by kkrofft (OH) on July 28, 2008 at 7:14 PM
  This message has been viewed 83 times.
In Reply To Re: Nope! If you are blowing the dipstick out, it almost posted by Driggers on July 28, 2008 at 03:15 PM
Message in just doing the rings if you have it apart you might as well do the bearings and have the heads rebuilt too. Do a 120K maintenance while it's apart. At that point it might be better to look into either a long block from Kyle at Import Parts Pro or find a good used engine with good compression.
I bought a JDM clip for my swap. The engine had ~60K on it and it has really great compression. It runs really strong.
If you look you can get a good used engine much cheaper than a rebuild.
KKrofft
