TwinTurbo.NET: Nissan 300ZX forum - Well for now I im going OEM FPR replacement.
Drk93TT
on July 28, 2008 at 3:14 PM
Works fine doesn't mean it is correct. All I am saying
posted by kkrofft (OH)
on July 28, 2008 at 02:58 PM
I have the 300 rail kit with SS lines, hopefully I can just replace the fpr with an aeromotive if i ever do need one? or is there more plumbing involved?
Thanks for ur input also kkrofft
Fuel Pressure at idle
Drk93TT
13:47:19 07/28/08
Where are you tapped into on the fuel line? (n/m)
Pushin'twins
13:56:23 07/28/08
directly after the fuel filter about 1" (n/m)
Drk93TT
14:00:46 07/28/08
If I read the tech doc correctly
FuerGrissa
13:59:57 07/28/08
I agreee on a small discrepincy
Drk93TT
14:02:43 07/28/08
It wouldn't likely be the pump, but rather the FPR. (n/m)
ZLover4Life
14:00:12 07/28/08
That's what I was thinking, but he's tapped in before it (n/m)
Pushin'twins
14:02:26 07/28/08
Yep, it is directly after the fuel filter
Drk93TT
14:03:26 07/28/08
lol that doesn't exclude it from being the FPR. (n/m)
ZLover4Life
14:04:15 07/28/08
My Dampner and FPR I beleive are OEM
Drk93TT
14:07:40 07/28/08
The best way to determine if the FPR is bad .....
twinturbineZ
14:17:47 07/28/08
or you could have an obstruction in the fuel line (n/m)
twinturbineZ
14:19:14 07/28/08
thats how the FPR works
AntiHero
14:12:50 07/28/08
that what you're supposed to do.... (n/m)
twinturbineZ
14:22:06 07/28/08
I had an issue with fuel pressure last year after my swap.
kkrofft (OH)
14:11:59 07/28/08
should I replace with OEM FPR?
Drk93TT
14:15:36 07/28/08
Im reading posts that OEM works fine
Drk93TT
14:28:51 07/28/08
yes, it does (n/m)
14:39:25 07/28/08
thx tdogg (n/m)
Drk93TT
15:14:26 07/28/08
kkrofft (OH)
14:58:20 07/28/08
Well for now I im going OEM FPR replacement. -
Drk93TT
15:14:08 07/28/08
probably an FPR more then pump
AntiHero
14:14:04 07/28/08
Do you have a way to test the pressure.....
Chad M (CA)
20:50:30 07/28/08
