TwinTurbo.NET: Nissan 300ZX forum - need to run a compression check at a minimum
Subject need to run a compression check at a minimum
Posted by aliaZ on July 28, 2008 at 5:05 PM
  This message has been viewed 80 times.
In Reply To Re: have you checked compression? posted by Driggers on July 28, 2008 at 03:19 PM
Message to determine where the problem is. I bet it isn't your valve seals.
Oil in the IC piping would indicate a turbo problem.
The fact that you are blowing out your dipstick indicates a possible piston ring problem or PCV problem
