TwinTurbo.NET: Nissan 300ZX forum - Question on 92 NA injectors for replace >>>>>>>>>>>>>>
Subject Question on 92 NA injectors for replace >>>>>>>>>>>>>>
Posted by ZUL8TR on July 28, 2008 at 4:51 PM
  This message has been viewed 128 times.
Message I think I have a dead injector (rear passanger) since no ticking sound with stethascope at this injector when running. No check engine light on or code caught when engine went to 5 cylinder operation. Should there be a code?
I will be checking harness for battery voltage and continuity to ECU and Ohm the injector if I can easily (Ha!) get the connector off.
If injector needed are there preferred new factory upgrades for a later year NA that are compatable with the 92 connectors that are better than ordering for the 92? Should all 6 be done? Have 84,000 on Odo.
Which site sponser would have these?
Help greatly appreciated
Thanks
ZUL8TR in Orlando,FL
