TwinTurbo.NET: Nissan 300ZX forum - 90-94 are 8 Bit. The 8 bit refers to the data bus
Subject 90-94 are 8 Bit. The 8 bit refers to the data bus
Posted by kkrofft (OH) on July 28, 2008 at 12:41 PM
  This message has been viewed 58 times.
In Reply To 90-94 ecu posted by 300zxNA2TT on July 28, 2008 at 12:03 PM
Message the ECU processor runs on. The later cars moved from OBDI to OBDII spec which required a 16 Bit CPU. The 92 will work if it has not been upgraded to use larger injectors than what you have installed.
KKrofft
