TwinTurbo.NET: Nissan 300ZX forum - Could be leaking from the either of the two hard pipes
doug8867
on July 27, 2008 at 10:45 AM
after Egr delete water leaks
posted by Criffdog
on July 27, 2008 at 02:34 AM
that are near where the EGR used to sit. You might not have got them
tightened back down well, or you didn't apply RTV to the surfaces before
tightening. Shouldn't require a tranny pull to fix if that's the problem.
Criffdog
02:34:31 07/27/08
Could be leaking from the either of the two hard pipes -
doug8867
10:45:31 07/27/08
Re: Could be leaking from the either of the two hard pipes
Criffdog
22:22:49 07/27/08
Yeah, that should work as long as you tightened it down
doug8867
07:54:38 07/28/08
Check the two hoses that connect to the
ZXRider(SoCal)
16:02:12 07/27/08
