TwinTurbo.NET: Nissan 300ZX forum - Dexron II IS automatic transmission fluid (ATF).
zoom
on July 25, 2008 at 7:54 PM
Not ATF. It should be Dexron II or compatible.
posted by MixManMash
on July 25, 2008 at 04:27 PM
It is a hydraulic systems fluid suitable for use in both hydraulically actuated steering systems as well as automatic transmissions.
Power Steering Becomes stiff
BlitzSRM
16:09:42 07/25/08
Chekc your fluid levels. You can have a slow leak causing
Z_Cherub
16:20:18 07/25/08
MixManMash
16:27:36 07/25/08
Good to know. I was going off of instructions from another
Z_Cherub
16:44:04 07/25/08
No problem. Dexron II is commonly used in Automatic
MixManMash
16:47:58 07/25/08
Dexron II IS automatic transmission fluid (ATF). -
zoom
19:54:56 07/25/08
Depends. As long as the ATF states compatibility.
MixManMash
01:11:25 07/26/08
Dexron type ATF as per service manual.
ZDUCTIV
11:35:56 07/26/08
