TwinTurbo.NET: Nissan 300ZX forum - Yes - check the CAS. Might be as simple as a loose plug?
Subject Yes - check the CAS. Might be as simple as a loose plug?
Posted by jzack on July 25, 2008 at 7:14 PM
  This message has been viewed 90 times.
In Reply To 90 300zx tt won't start intermitant spark no code, Help! posted by Bizadam7 on July 25, 2008 at 06:54 PM
Message When you checked for a spark:
- Are you sure that test coil pack is good (just a thought)?
- Did you try it out on a few cylinders or just in one place?
The only other thing that comes to mind is the PTU (other side of engine from CAS). It sends the firing signal to the coil packs.
