| All prices from Concept Z ([ www.czp.us ]). You can get the same stuff elsewhere, but their rep is 10+. Your injectors will continue to fail. Switch to new style. Best option: 300 Degree 300ZX High Performance Fuel Rails w/ Nismo 740cc Injector Kit $1270.00 FMIC is junk. Here's a good upgrade (Stillens are better but must add cost of new ducts): Z1 Sidemount Intercoolers SMIC Set $775.00 Other chip upgrades are cheaper but choose them at your own risk: JWT 300ZX ECU Upgrade Twin Turbo $575.00 Your other turbo will die as well. Do both. Cheapest bang for buck (use existing downpipes): JWT 300ZX Sport 500 Turbos $1995.00 --or-- Costs more up front but you'll not regret it. My advice, avoid Z1 drama and buy the kit through Coz @ CZP: Z1 GT600R Turbo kit $2495.00 and SZ Super Split Stainless Steel 5 Bolt Downpipes $550.00 You can also spring for bigger turbos, SZ 3" expansion DPs, boost controller, etc. but then you're down a slippery road. More upgrades, more money, rinse/repeat. There are other good options as well, but these are pretty tried and true. Some general advice about buying a Z Good luck!
