TwinTurbo.NET: Nissan 300ZX forum - Fuel setup question
Subject Fuel setup question
Posted by turboz32 on July 23, 2008 at 11:18 AM
  This message has been viewed 150 times.
Message i just bought and installed PE 850 injectors with 300 degree fuel rails. I did the stock serial configuration. The car runs terrible. It starts up with a rough idle and when i give it gas it does not rev as its supposed to. Like it has a bad hesitation. After about twenty seconds of running it stalls out, and wont start back up, due to what i can only assume is flooding. I was fooling around and took off the regulator and damper and it started up fine, so i thought i could test it out. I took it around the block once and found that the car would not boost over four lbs. I put the damper and regulator back on and now I am having the same problem as before. My question is, is there anohter way i should have set it up?
