TwinTurbo.NET: Nissan 300ZX forum - The only difference between the blocks is the NA has
Subject The only difference between the blocks is the NA has
Posted by na300zx (OH) on July 23, 2008 at 8:29 AM
  This message has been viewed 184 times.
In Reply To The block is different. I think you can drill posted by 600ZXR on July 22, 2008 at 09:33 PM
Message check valves where the oil filter tree bolts up and the TT has plugs (there
are obviously other differences on stuff that bolts up, but I am referring to
the actual block casting and plugs... nothing that bolts on). The actual
casting is identical.
