TwinTurbo.NET: Nissan 300ZX forum - Sounds like the 1st starter was on its way out -- is the
Subject Sounds like the 1st starter was on its way out -- is the
Posted by jzack on July 22, 2008 at 10:35 PM
  This message has been viewed 86 times.
In Reply To Issues, issues, issues posted by dugsmok on July 22, 2008 at 09:09 PM
Message 2nd starter Nissan or aftermarket? Aftermarket unit's don't always match up well with the flywheel (gear teeth) and you get grinding. A local shop here that works on a fair number of Z's only sources them from Nissan to avoid this issue.
Rough Engine Issues: You'll need to run your ECU codes and see if any system errors are being reported - easy to do this yourself. Hopefully you haven't lost an injector - shaky and rough is how that feels but it could be some other things too.
