TwinTurbo.NET: Nissan 300ZX forum - No, not to replace the sides and bottom rubber. Only if
Subject No, not to replace the sides and bottom rubber. Only if
Posted by doug8867 on July 22, 2008 at 1:04 PM
  This message has been viewed 218 times.
In Reply To What's involved to replace the rubber trim around the glass? posted by TTkeeper on July 22, 2008 at 12:45 PM
Message you are replacing the black piece that goes along the top do you need to
unglue the glass. The other rubber just peels out from the corner pieces
and has a groove in it that fits around the edge of the glass. The top metal
corner pieces may get bent on removal of the molding beneath it so you
might order replacement beforehand, or you can just wait and see if yours
pop out with no problem.
I replaced all my moldings last summer. Here is the part numbers:
molding that goes around side and bottom of rear windshield: 90372-30p00
RH corner molding: 90366-30p00
LH corner molding: 90367-30p00
Was about $120 if I recall for the 3 pieces.
Hope that helps.
