TwinTurbo.NET: Nissan 300ZX forum - Rounded clutch pipe nut
Subject Rounded clutch pipe nut
Posted by 600ZXR on July 21, 2008 at 1:27 PM
  This message has been viewed 76 times.
Message How hard is it to put a new flare nut on the clutch piping at the "T" junction? I did Robo's bleeder tube delete but the clutch line I used from the donor car (for my AT to 5spd conversion) had the nut slightly rounded. When I tightened it down to its stopping point the tube inside didn't bottom but the nut won't turn any further. Would it be better/easier to cut the line put a new flare nut on and reflare the tube or replace the whole line? I really don't want to pull the engine but if that is the it has to be done then I will give in. This is the long tube that runs behind the engine to the master cylinder. Thanks in advance for any help or suggestions.
