TwinTurbo.NET: Nissan 300ZX forum - Here's the hints Kinda long.
Subject Here's the hints Kinda long.
Posted by jjpp2Z on July 19, 2008 at 4:15 PM
  This message has been viewed 132 times.
In Reply To Failed State Inspection, Need Help posted by gjohnson25 on July 19, 2008 at 11:33 AM
Message 1st ,you could get it pass if you can ask the Tech to put a fan in front of the car blow the cold air to the radiator while doing a test. Or you can test the car on the colder day
2nd, you could retard the timing little bit. This is a 20/20, by retarding the timing car will run rich therefore HC and CO will increase. Plus our car is computer controll timing I'm not sure this helps much.
3rd Run higher octane or decabornized the combustion chamber.
I don't know why you said after installed EGR delete kit it got better, It should the other way around. The EGR system main function is to reduce NOx.
