TwinTurbo.NET: Nissan 300ZX forum - Or TOO well seated.
Subject Or TOO well seated.
Posted by my91z on July 19, 2008 at 6:11 AM
  This message has been viewed 18 times.
In Reply To You sure the ECU plug is well seated -- that would posted by jzack on July 18, 2008 at 04:44 PM
Message When I swapped ECU's before I tightened the center screw holding the connector to the ECU TOO much. It actually pulled up the outer ends of the connector and caused them to loose connection with the pins causing some cylinders not to fire. Backing off the screw a bit let the connector seat properly and things were fine.
Mike
Click here to e-mail me!
