TwinTurbo.NET: Nissan 300ZX forum - Clean the IAA unit and see what that does. Failing
Subject Clean the IAA unit and see what that does. Failing
Posted by 5280Z_nightstalker on July 19, 2008 at 12:34 AM
  This message has been viewed 102 times.
In Reply To Idle issue posted by djrz on July 18, 2008 at 11:11 PM
Message injectors probably are a problem to but I dont think it would cause the car to almost die. Here is a link to replacing it but if you take it off just spray it very well with carb cleaner.
IAA
I think you will have idle issues as long as you have failing injectors but for the car to almost die seems like maybe more then injectors.
Injectors
Good luck but you really will have to just run test to see whats causing it.
