TwinTurbo.NET: Nissan 300ZX forum - electrical problem...
Subject electrical problem...
Posted by pearllady91 on July 18, 2008 at 4:11 PM
  This message has been viewed 107 times.
Message Ok, For 3 months, I've been seeking for an rought idle issue.
today, I unplugged the ECU connection to take the resistance of the injectors.. 13 ohms all 6.. replugged the ecu and the car would not start anymore... So I mooved a little bit the harness just next to the ecu plug and tried it again and it started.. while idling, I played with the same hundreds of wires and suddently, my idle came back to normal !! And sometimes with the key ON , car not running, while I move gently the harness, the AC fan comes in, fuel pump other times, few relays cliking under the dash.... the harness is so sensible to movement that it's impossible to pinpoint the wire or connection who may be deffective. please, I would like some advises...thanks
