TwinTurbo.NET: Nissan 300ZX forum - I think the ECU just needs to recalibrate.
just4kinks
on July 18, 2008 at 4:09 PM
NA TPS voltage setting (.45 doesn't work)
posted by ttzcadet
on July 18, 2008 at 02:20 PM
The ECU thinks the throttle is open at 0.45V because it was previously calibrated to 0.2V. Adjust it to 0.45, check continuity at the switch with a multimeter, and recalibrate (step 6 below). Then check again with Blazt.
La-Z-Link
ttzcadet
14:20:23 07/18/08
Re: NA TPS voltage setting (.45 doesn't work)
txq45
15:11:28 07/18/08
Manual shows 0.4 - 0.5V, unless it changed for some years.
just4kinks
15:58:00 07/18/08
I think the ECU just needs to recalibrate. -
just4kinks
16:09:55 07/18/08
Re: I think the ECU just needs to recalibrate.
ttzcadet
17:17:21 07/18/08
You did unplug it with the ignition on and then plug it back
Audioquest
19:22:56 07/18/08
