TwinTurbo.NET: Nissan 300ZX forum - CAS, PTU, MAF, AAC, Coolant Temp Sensor, Injectors
Subject CAS, PTU, MAF, AAC, Coolant Temp Sensor, Injectors
Posted by Audioquest on July 18, 2008 at 9:09 AM
  This message has been viewed 163 times.
In Reply To Re: Could be intermittent problem cause by corroded terminals posted by ZUL8TR on July 17, 2008 at 04:46 PM
Message Air Regulator, TPS, are the most critical ones for your condition and can all be pulled with the engine in place.
Also test the Coolant Temp Sensor and Injectors with a multimeter while the connectors are off.
A faulty CTS can make it do some weird things.
