I have a TT 90 with what I believe is a stuck, bent, broken valve. It hesitates very bad and has a tapping on the driver side from the exhaust. Which i slightly had then turned into major hesitation. I believe the culprit is the #6 Cylinder as I can unplug the coil pack with no change in idle. I have swapped the coil pack, changed the injector as well as new connector. The plug is pretty fouled as well. Any ideas or input, I know there is a problem with the 90 head. I just haven’t yet done a compression test.
